Wonder is someone can tell me. Can I use my Laptop with a MONO Left for the Speaker output and the MONO Right for my Headphones from one sound card... Will the Sound Qaulity sound bad for my audience or will they not even notice that i'm playing for them in MONO...? Any other suggestions with only one sound card output on a Laptop...
Thank You...
Thank You...
geposted Wed 09 Aug 06 @ 8:19 pm
well, I think only experts realize if sound is mono or stereo, neverthesless if you want to work with a laptop and not spend too much, get the soundblaster live 24 bits usb, you can configure it in mode 4.1 within vdj and to work in stereo and to use prelisten too.
Manquin DJ
Manquin DJ
geposted Thu 10 Aug 06 @ 1:03 am
besides the tip from manquin_dj, keep in mind that you will need the full version of VDJ to use it like that. Note also that you will need the full version also if you would like it to set it up like you described yourself.
To get a little more pro you could also get an Esi u46DJ. This is the recommended card for VDJ use. You could later also add time code vinyls or cds with this card.
Ewout
Ewout
geposted Thu 10 Aug 06 @ 8:42 pm
