Forum: VirtualDJ Skins
Topic: Seek While Paused without Jog Wheel
Is there a way to seek without the jog wheel while paused. When I use buttons with the seek action, I can hear the track, while in Play mode. In Pause mode the track moves but is silent when using the same buttons. I'm trying to create a skin without using a jog wheel.
TIA
Greg
geposted Thu 10 Aug 06 @ 5:40 am
why do you need to hear something on the track when it is on pause?
<button action="scratch" value="1" chan="1"></button>
Adjust values to suit, negative numbers will reverse direction, chan I assume you know.
DJ Mykel
I am assuming you want buttons to adjust the song and cue by ear.
Mykel
Yes, that's correct. Thanks for your help!!
Greg
Hi Mykel,
I've tried using that action and it doesn't work for me. With the scratch action & those paramaters, nothing happens. Is there something else that could be happening?
Greg
