Hey
i was thinking of buying the hercules mk2 and getting the virtual dj software with it. i would only be using it for home use. can i use the console and virtual dj without any other hardware etc? and is it any good?
thanks m kohler
thanks m kohler
geposted Thu 10 Aug 06 @ 11:12 am
          yes you can, and its great for home use... ;)
you wont find anything that cheap with that quality... all-in-one box
- mixer
- controller for vdj
- dual soundcard
For home use its perfect, for profesional use its even ok...
- mixer
- dual soundcard
geposted Thu 10 Aug 06 @ 5:51 pm
          thanks a lot i am hoping to get it soon. what kind of laptop would be good to run it on as in spec if i was to buy a laptop aswell?
    geposted Thu 10 Aug 06 @ 10:08 pm
          VDJ + the Hercules console will run on ANY new laptop ;)
All NEW laptops have enough power to to that, and all come with USB ports:)
So you can get a cheaper one if its only for audio home mixing..
If you also want to use the laptop for video mixing, or playing games, get a laptop with a dedicated graphic card (non shared memory) with at least 128mb ram...
And djing is addictive... So you will probably collect mp3s like crazy;) hehe.. So as much harddisk space as you can, but external drives comes cheap these days and offer enormous space.. so its easy to expand that ;)
geposted Thu 10 Aug 06 @ 10:16 pm
          thanks you were a great help :) much appreciated
    geposted Thu 10 Aug 06 @ 10:18 pm
          if your looking  for one i am selling mine.
    geposted Fri 11 Aug 06 @ 12:02 am
          its ok the now but thanks cos i think i need to wait till xmas anyway but thanks for the offer :)
    geposted Fri 11 Aug 06 @ 11:22 pm
