Hi I just bought myself a DJ Console MK1 (this is the only one available to me here in australia) and also bought VDJ online yesterday. I downloaded VDJ from the link provided installed opened VDJ entered the serial number it then opens up to the atomix opening screen displaying the correct email address i registered with and then minimizes itself to my taskbar and appears to have frozen.
Is there something i missed upon installing?
Any help would be greatly appreciated.
My PC specs are AMD Athlon 64 3800+, 1 Gig RAM, Windows XP Pro SP2, Twinhan DTV HD Tuner PCI card, NVIDIA GeForce FX 5700, Direct X 9.0c (latest update tonight), Asus A8V motherboard latest bios and drivers.
geposted Fri 11 Aug 06 @ 5:00 pm
You must change your resolution screen to at least 1024x768.
I think your screen is in 800x600 and that stops VDJ from opening.
geposted Fri 11 Aug 06 @ 6:40 pm
yes, is so simple like Jeremk mentions.
geposted Fri 11 Aug 06 @ 6:44 pm
yep that was exactly the case, i figured out it had to be at 1024 just before reading the reply.
Thanks for the speedy response and sorry for posting so early.
Perhaps this can be added to the FAQ and/or Knowledge base?
geposted Fri 11 Aug 06 @ 6:47 pm
only staff can decide that lol.
geposted Sun 13 Aug 06 @ 7:17 pm
