Forum: VirtualDJ Skins
Topic: More than 1 action
Is there a way to apply more than 1 action to a button?
Greg
geposted Mon 14 Aug 06 @ 1:11 am
you can assign a rightclick value or double click value
Is there a way to have a button do something while in pause, and the same button do another action when playing?
Or even better, have the jogwheel scratch through the track, but if loop is activated the jogwheel changes the length of the loop?
I was thinking of pannels to do that, but i'm not sure it is possible. And i would prefer knowing it is possible before i try it.
pannels is probably your best best, u should be able to assigned the loop button to also be a pannel button, but sounds like a mess of headaches...skinning is so addictive eh
Have tried many different ways to add two different functions to buttons, either by scripting the button twice or assigning functions to leftclick/rightclick combinations. So far I have drawn a blank.
As to defining actions relating to deck state (play/stop) I don't think this is possible, unless the function is relative (such as stop/cue command)
I do agree with phillydj on pannels, and have used pannels to map different functions to buttons, albeit using the same graphics. Go ahead and give it your ideas a try, if you hit any difficulties, there are lots of users out here willing to lend a hand...
see post http://www.virtualdj.com/forums/53154/Skins/CUSTOM_SKIN_SERVICE.html
DJ Mykel
DJ Format
