If i connect the virtual dj through a pioneer cdj 800 when i move the pitch control on the cd player will the bpm change on the screen and pitch control move on the screen too
geposted Mon 14 Aug 06 @ 6:55 am
No ..its called timecode you can search the forums for tccd , the song will speed up , but it wont move the pitch slider on the skin and u have to hook the cdj to your pc through asio soundcard not vice versa..also if your looking to try tccd, keep in mind that demo version only can use 1 tccd for 5 minutes
geposted Mon 14 Aug 06 @ 9:17 am
