you all should make a plugin that cuts and pans at the same time
geposted Mon 14 Aug 06 @ 7:09 pm
Ok but in which order? I'll make one with selectable panning and cutting lengths, so you can calibrate them as you wish. After it's done, tell me which values are your favourite ones and I'll make them as default.
Do you mean it's done in this way: "left - silence - right - silence - left - silence - right - silence - <repeat>"? Obviously you'll be able to change the "duty cycle" and the wafevorm which controls the cutting behavior.
geposted Mon 14 Aug 06 @ 8:14 pm
