It would be great if VDJ could keep the right position of tempo slide when changing the song into deck.
Actually when you change the song the virtual slide of tempo in VDJ restart from 0 even though the hardware slide isn't in that position.
I think it is gonna be a easy fix.
geposted Wed 16 Aug 06 @ 12:16 pm
Go into config panel -> Fame settings -> Disable auto pitch reset
geposted Wed 16 Aug 06 @ 12:35 pm
why is it called FAME anyway?
geposted Wed 16 Aug 06 @ 3:02 pm
