I just got Fast Track Pro from M-Audio... the problem is the soundcard has 4 outputs but no inputs. beside that it does have MIDI (I/O) and S/PDIF (I/O) and TRS (2 - I/ 2 - O). my question is, how would i connect the turntables to soundcard when no rca INPUTS are available? would i use the TRS inserts? or use the S/PDIF? any feedback is appreciated.
thx
thx
geposted Thu 17 Aug 06 @ 4:44 am
Someone mentioned once that Fast Track Pro was incompatible with VDJ, but I don't see why it would be. You will need to use the TRS inputs and make sure they are properly routed to VDJ Asio.
geposted Fri 18 Aug 06 @ 10:44 pm
