I've just discovered a new proplem with my copy of 2.0
When I hit the "synch" button, ordinarily the track on that particular side will automatically match BPM, and start up in synch with the beat pattern on the other side.
Now with 2.0, (it depends on the song, and there seems to be no logical reason), even though the beat markers are in the right locations in the track (relative to the actual beats), VDJ will start the track TOTALLY out of synch.
It will set the BPM correctly, but start the song so far out that it can't be recovered. ....I mean like 2 1/2 beats out....
The problem is repeteable,.. it will do the same thing consistantly with certain tracks.
geposted Sat 26 Jun 04 @ 3:28 pm
i'm not sure...but there is a new beatmatch engine in v2.0..
could be a skin problem (not compatible with new engine)
hope someone can help you on this
geposted Sat 26 Jun 04 @ 4:01 pm
Happens to me sometimes too.
Proto
Proto
geposted Mon 28 Jun 04 @ 3:36 pm
it happen sometimes to me too.....the beat goes out of sync of 1/2 beat....
geposted Mon 05 Jul 04 @ 6:51 pm
It seems to me the sync button tries to match amplitueds of waveforms. So if the first song has bass drum beats squarely on the beat, and the second song has them 1/2 a beat off, the sync buton will match drum beat to drum beat, resulting in the songs being off.
geposted Fri 16 Jul 04 @ 5:16 pm
the problem is that vdj uses cgb and beats to sync...
so u must adjust cgb to fit under beats!!
then all works just lovely ;) lol (sync, loops etc)
but it is very important to adjust bpm and cgb for songs, to make vdj run smooth...
read this post :
https://virtualdj.com/forum/display.html?topic=5408
then all your problems will be history ;)
read this post :
geposted Fri 16 Jul 04 @ 5:29 pm
Thanks, norway dj,.. however I'm not a *complete* moron!
I have the cbg, bpm, etc.. adjusted properly, and that is not the problem... There is a glich in the programming somewhere.
geposted Sun 18 Jul 04 @ 6:56 pm
I experienced the same problem today. I will read this post again:
I hope the problem “will be history.”
OO
OO
geposted Tue 03 Aug 04 @ 6:18 pm
hope so too...
but remember.. there is a PITCH and a NUDGE function. If to beats are not PERFECTLY in sync, even if u think you have made the best cbg and bpm's for songs, there might still be use for tiny changes in pitch and nudge to make them perfectly synced...
VDJ does help u a lot, but sometimes u gotta help VDJ too ;)
geposted Tue 03 Aug 04 @ 6:48 pm
Look, Norway dj,.. I know you are trying to be helpful, but as I said before, this ain't my first rodeo! I don't know how to make it any plainer for you, but I'll say it again:
No matter how perfectly the cbg, etc... are fine tuned,.. the tracks can start as much as 2 & 1/2 beats out of sync.
geposted Sun 08 Aug 04 @ 2:29 am
blackgold9: “…if the first song has bass drum beats squarely on the beat, and the second song has them 1/2 a beat off, the sync buton will match drum beat to drum beat, resulting in the songs being off.”
The VDJ DEV Team should consider adding something like Acid Pro's "Beatmapper" to the software. Anyone who is curious about the product can download a copy of the demo and manual here:
http://mediasoftware.sonypictures.com/download/step2.asp?DID=401
geposted Sun 08 Aug 04 @ 5:29 am
