How can i send my mix out to 4 people from my own computer ??
Because i tried it from my own computer and then go to the adres
But it doesnt work
Do you guys have any suggestions broadcast it on a radio server ?
But it doesnt work
geposted Fri 18 Aug 06 @ 1:29 pm
Yes, go to www.shoutcast.com/download/ and click on "Be a Server". Read the instructions, you will need to edit the ini file with your proper configuration. Once you're done, you'll be able to broadcast with VDJ using winamp. Your upload bandwidth determines how many listeners you can broadcast to and at what bitrate.
geposted Fri 18 Aug 06 @ 10:22 pm
Hello, using the option to broadcast of my dj console, it doesn´t anything, what I must do? i need a plugin, but i don´t know how to do it
geposted Sun 20 Aug 06 @ 9:02 pm
Look at page 18 of her User Guide under Help to get you started.
geposted Sun 20 Aug 06 @ 9:39 pm
hi, i´m spanish, so my english may be not correctly- thanks but, could you be more explicitly? i need to know how to emit my sesions, but the dj console needs a plugin and i don´t know wich one is.
geposted Sun 20 Aug 06 @ 10:08 pm
hi again! i have the plugin of winamp yet, but now when i´m broacasting, and i´m connect to the url said, it doesn´t work.
geposted Sun 20 Aug 06 @ 10:31 pm
Hi! I'm not shure but I think (as I remember) that with the Shoutcast system you can listen the radio only with winamp.
I've downloaded the "Microsoft Windows Media Encoder" that (I think) is better.
geposted Mon 21 Aug 06 @ 8:35 am
Your wrong. Shoutcast is what you need to "transmit / broadcast" your radio over the internet through Winamp. Look into it in more detail !!!
geposted Tue 22 Aug 06 @ 2:31 am
Sorry DjGazUK, I've tried Shoutcast 3 years ago and I was shure that the other users were allowed to listen me only with WinAmp.
Maybe I've not understoot how to connect to my broadcast with other software...
(Sorry for my english...)
DaVe
DaVe
geposted Tue 22 Aug 06 @ 8:01 am
