today i purchased an external soundblaster live 24 bit sound card to test on the trial of virtualdj before i buy the full version.
the sound is slightly distorted and crackly? does anyone know how to fix this?
itr;s nothing to do with the sound set-up or drivers as the output through iTunes via this card is absoluetly perfect....no distortion.
i've tried changing the audio settings in virtual dj but still horrible crackling on high notes and also stuttering ocassionaly on the waveform
help!!
help!!
geposted Fri 18 Aug 06 @ 9:51 pm
Before VDJ4 is out (in a few days), use that card in direct sound mode, and not asio
geposted Fri 18 Aug 06 @ 10:04 pm
please can you clarify what you mean? what setting do i need to change to stop the crackling?
it seems connected to VirtualDJ only as WinAmp, itunes etal all work perfectly with great sound clarity.
i'm becoming increasingly frustrated with the problems of virtualdj and now wondering if i should bother with full version...
many thanks
many thanks
geposted Fri 18 Aug 06 @ 10:31 pm
you could also try to increase the lantency of your soundcard. when you set it too low, the sound could also crackle. The faster your cpu, the lower your latency can be set.
geposted Tue 22 Aug 06 @ 1:52 pm
Yes it could be either latency or 48khz mode you're having issues with. VDj 4 should support the 48khz mode unlike previous versions.
Regards.
Regards.
geposted Tue 22 Aug 06 @ 3:45 pm
Go to CONFIG>SOUND CARDS and tell us how you have it set up right now.
geposted Tue 22 Aug 06 @ 8:24 pm
I have that sound card and no problems at all with Pro version. I didn't adjusted anything, it works right away with drivers from cd.
Why are you using Live when you have MK2 and why do you use Trial when you have Home Edition of VDJ? I'm confused.
geposted Wed 23 Aug 06 @ 7:36 am
