is there a good echout out there that doesn't lag. i notice the one we have it takes like 2-3 seconds be4 it gets activated and maybe it needs to be updated by adding new features on it if possible.
thanks.is there a good echout vst out there.
geposted Sun 20 Aug 06 @ 12:37 am
What do you mean with "that doesn't lag"? A reverb? Or that will echo the previous sounds since activated, and not after a small lag? What do you want to add as new feature?
geposted Sun 20 Aug 06 @ 2:12 am
