I get major feedback from my Stanton str8-80 when I am playing a time encoded vinyl record. I am using a UREI 1601S mixer also. How can I get rid of the feedbac/whining noise????
Chris
Chris
geposted Mon 21 Aug 06 @ 11:19 am
ground TT to computer, try to mixer too, or get ground loop isolator.
geposted Mon 21 Aug 06 @ 11:30 am
my turntable does not have a ground. i think its comming from the record itself. is this normal?
geposted Mon 21 Aug 06 @ 12:14 pm
You can attach wire to any metal part on your TT or you can tape ground on your cables and try it that way. You TT's are making noise because they don't have ground and they are grounding on your mixer or computer. Getting the Ground Loop isolator is the best solution.
geposted Tue 22 Aug 06 @ 3:20 am
the wining noise could be the actual sound of the vinyl leaking through to the system. Have a listen to the timecoded vinyl through your speakers, see if it's the same noise your hearing.
If it is, have a look at your soundcard settings, prehaps it's monitoring the input through to the outputs.
geposted Tue 22 Aug 06 @ 4:04 pm
