Forum: Music discussion
Topic: Is it possible to hold a song
I was just wondering if its possible to hold a song with the MK2 Console, you know like when ur using a cd turntable and u put your hand on the deck and it stops the song, is it possible with the console?........ would make scratching alot easier
geposted Tue 22 Aug 06 @ 1:41 am
ktilakPRO InfinityMember since 2006
unfortunately not... the hardware doesn't have the capability for touch sensitivity..
but the xp10 does, possible upgrade... or just CD or vinyl tables with timecode
geposted Tue 22 Aug 06 @ 3:55 am
xeonPRO InfinityModeratorMember since 2004
you can do it with buttons of MK2, but not with wheels.
geposted Tue 22 Aug 06 @ 10:41 pm
hemanHome userMember since 2005
so the wheels dont turn ...? what if you pull it back a bit ??? will it just go back ???
i had a question ....if i buy an mk2 do i become a VDJ member like of the site like a home eddition user ...cuz i know you get a VDJ version with mk2 but do you get membership ??
geposted Fri 25 Aug 06 @ 12:08 am
how do u do it with the buttons, assuming its not the cue button
geposted Sat 26 Aug 06 @ 6:39 am
