I downloaded the 30 pack of visualizations (dj-in-norway) and i see them in the video ouput screen, but they dont seem to be responding to any music or beats. Whether a song is playing or not, they seem to be doing the same thing. For instance, the whitecap visual is only showing a flat green line when a song is playing. Is this normal, or is it supposed to be reacting to music? Does it only work for an external mixer and line-in, as opposed to just using the onscreen mixer? Thanks.
geposted Tue 22 Aug 06 @ 8:39 pm
I do not think they work in the advanced settings of the sound card.
Try it in 4.1 and see how it works for you.
geposted Wed 23 Aug 06 @ 12:32 am
they work better with hardware acceleration, if your video card doesn´t support it then effects won´t run properly, and yes they move when you play a song.
geposted Wed 23 Aug 06 @ 4:53 am
hi, what sound card do you have.
I have a maya44 usb (i think the problem is with asio cards) and i solved it on my computer by using the "time-coded vinyl" option in the soundcards tab of the config menu. Then i set the card up the way i wanted it by clicking the button that appears when you highlight the time-code button i just mentioned.
Then it worked fine for me after that.
Hope that helps (I'll explain it again if that wasn't very clear). :)
Andy.
Andy.
geposted Thu 24 Aug 06 @ 1:11 am
