OK, I've used search and didn't find any answers.
I want to use multi-instance skin, to have 4 decks. Now I have all the skins downloaded (trying the "Multi Instance Skin" 1.5, there's 3 of those showing up, up part, down part and v3.0. Looks like 3.0 loads both parts.
The problem is that both skins (instances of vdj) are one on top of other and wouldn't move. They're like enlarged windows, can't do anything to them.
doesn't look like anyone has the same problem, everybody's pretty happy with it. Not sure how to get windows movable here...
any ideas?
any ideas?
geposted Wed 23 Aug 06 @ 9:17 pm
Movable windows? Simple, just unmaximize both instances. :)
If you're having trouble with the grabzone though, it's sometimes (depending if programmer of skin included the grabzone parameter) only a certain area of the skin, the 'Virtual Dj' sign or top-left corner of skin, that you can click on and move the 'window' around your screen.
Hope it helps.
Hope it helps.
geposted Wed 23 Aug 06 @ 11:40 pm
Disable the fullscreen mode on the skins
geposted Thu 24 Aug 06 @ 12:53 am
Figured out - I didn't notice the "grabzone" before :)
geposted Fri 25 Aug 06 @ 2:48 am
