Greetings-Peace
Just downloaded the trila version - It pops up - I see the 20 days left message in the bottom left corner - Then it goes away - It's minimized - Clicking on it doea nothing - Its just there - In the minimized row - Any help?
geposted Wed 23 Aug 06 @ 11:33 pm
1) Try searching the forums first before posting, same issue has been reported few times already.
2) Change your screen resolution to at least 1024×768, should solve the problem.
Regards.
Regards.
geposted Wed 23 Aug 06 @ 11:45 pm
Hello,
the skin you are trying to use (default skin is 1024x768) does not fit into your screen.
Try to increase your desktop resolution, and report back.
geposted Wed 23 Aug 06 @ 11:46 pm
