Hi!
Vdj4 is amazing!
However, I find a minor bug (solved if you disable windows sounds):
when you press a shortcut involving the ALT key, vdj may play the windows beep sound.
this happens if, for example you have clicked (so focused) in the playlist list.
If your last click was not in a listbox or textbox, everthing is okay.
I appreciate your efforts in making vdj better!
thanks!
Vdj4 is amazing!
thanks!
geposted Thu 24 Aug 06 @ 5:48 pm
