The program won't start:
"Cannot initialise the program correctly (0xc0000135)"
Can anyone help me with that?
geposted Tue 29 Jun 04 @ 3:27 pm
it has something to do with the fact that it is a .net framework app... i think
so u must install the .net framework update for winxp first... (you must install this anyway, because there are more and more programs that will demand this)
.net framework is available as a windows update
geposted Tue 29 Jun 04 @ 3:39 pm
Yes this problem comes from the fact that the .NET Framework v1.1 is not installed on your computer. You can get it at the Windows Update website:
http://v4.windowsupdate.microsoft.com
macourteau
macourteau
geposted Tue 29 Jun 04 @ 3:46 pm
Thanks for the quick response!!!!
geposted Tue 29 Jun 04 @ 3:47 pm
