Hi
I was trying to accommodate a skin to my needs, and i discovered it used the old v2 format.
since formats 3 and 4 requires the logo (which is already present in my skin, both textual, and graphical, but in a panel), I began makin room.
First vdj throw an exception (error at line 0, even though this code was at line 200)
if I leave this code
and then it throws an error if at least one node has as last item a comment.
Just want to inform you, that sometimes comments should be removed by the skin, as they crash the engine.
Regards,
Pier
grabzone without logo
size width="347" height="17"
pos x="105" y="84"
grabzone -->
<!-- grabzone>
size width="147" height="17"
pos x="205" y="84"
grabzone -->
<grabzone>
pos x="565" y="84"
grabzone -->
this is to make room to the logo
grabzone
size width="89" height="16"
pos x="6" y="6"
grabzone
Regards,
Pier
geposted Fri 25 Aug 06 @ 12:22 am
