I cant get the Asio driver to work as it should in vdj4 however in 3.4 it worked fine.
My Motu 828 Mk2 wont play anything on Chann 1&2 in VDJ4....
I route the Vdj Audio setup like this
Inputs : none
Outputs : External Mixer
Soundcards : Asio Driver
Driver : Motu Audio Asio
Left Deck - > Chann 1&2 Right Deck -> Chann 3&4
And i only get output on Chann 3&4 - 1&2 is dead
This worked fine on Ver. 3.4 but on the new i cant get it to work?
Will this be fixed?
Oh and by the way, im a newly registred customer of this wonderfull program, just bought it now because i love it so much, and now i should be able to hook up my BCD2000 and use that for the first time since i got it 6 months ago :)
I am exspecting everything from VDJ4 :)
I just need that asio driver problem fixed, or i cant use both decks :(
Kind regards
Cosmodk
Inputs : none
Will this be fixed?
Kind regards
Cosmodk
geposted Fri 25 Aug 06 @ 2:20 am
Hi,
I encounterd a similar problem with asio routing on my Audigy 2, which I have written in First Impression thread. This is a quote from my post regarding this issue, as I found a work-around to my problem:
Hope it helps you solving the issue temporarily, but I'm hoping we get some feedback from staff on this.
Regards.
Quote :
Sound setup issue encounter with Audigy 2:
Since I'm only using an external mixer at home, I've tried the "External mixer" setting with the Primary Sound Card (4.1) driver, which worked fine, but the latency was unacceptable, so I tried the ASIO mode (with my Audigy 2) which created a problem: Left deck plays both on channels 1&2 and 3&4, while right deck plays ok only on one channel. Naturally the problem remains with the reverse L/R deck option, just for the other deck. So I tried different settings in my drivers (from 7.1, 5.1, 4.1) with the same result in VDj 4.
But luckily I found a work-around: with only a 2-lines mixer I gave up using samples, and selected the "3-lines mixer" mode, and selected the "1&2 Samples / 3&4 Left deck / 5&6 Right deck" option which works as it should, but I don't understand why the output order has been switched since 1&2 + 3&4 should work as a front/rear channels? Samples of course play on both 3&4 and 5&6 channels (which they shouldn't) if I use them.
This is probably my hardware (drivers?) issue, but would love to get some pointers what the problem could be.
Regards.
geposted Fri 25 Aug 06 @ 9:56 am
No sorry same problem still, however thanks for the input :)
geposted Fri 25 Aug 06 @ 10:41 am
