Topic: Pitch vs One TCV in V4.0
Hi,
I only have one turntable and I use to toggle the TCV control on the active deck. In version 3.4 when I was releasing the TCV control from let's say the deck 1 and with a pitch at +4% by example, the pitch was remaining at +4% allowing me to take control of the other deck with the TCV, but with version 4 when I release the TCV control with a pitch of +4% it goes back to 0%.
Does anybody figured out how to get that functionnality again or does it have been removed in V4.0?
Thanks
geposted Fri 25 Aug 06 @ 3:58 am
should not work like that...
Turn off Auto pitch reset, see if that helps
Hi,
if you means pitch reset in the options menu it is deactivated... I did try all I can think of, but it does the same... In sound setup I took one TCV... It can be a new bug I'm not sure. If someone have the same problem we will be able to tell.
Thanks
