For the most part version 4 works great however running two songs in sync, cut in the vocals effect and it causes it to semi freeze, and make the good ol sound you get when the cd player is skipping, it will all resume to normal function when you turn it off (the effect). However navigation the mouse there is interesting, move alittle.....pause.....move some more.... pause..... you get the jist. EDIT This only happens when you speed up the bpm of the song in question, it also happens if you playing the song by itself, speed up the bpm put on a vocals effect and freeze dried CHOP Suey
geposted Fri 25 Aug 06 @ 8:43 am
How do you have your sound configured?
geposted Fri 25 Aug 06 @ 9:29 am
I am having a similar problem.. When I am playing a song on deck 2 and enable vocals+ effect and do a back or forward scratch, it causes my computer to bog down and after about 15 seconds it releases and continues on until I scratch again then it repeats. Appears to do it in full screen and window mode. I tried different sound card configs. It seems to only do it on deck 2? task manager shows CPU chart to go to 100% for what it does capture when the computer is bogging down. Similar results when you load a song on deck 2 and turn on vocals before you hit play and scratch. Any ideas?
geposted Tue 26 Sep 06 @ 7:45 am
lower your proformance tabs!
geposted Tue 26 Sep 06 @ 9:24 am
Theres the problem with the 100 % cpu usage.
Try the above and see what happens
geposted Tue 26 Sep 06 @ 2:50 pm
I lowered the settings to the lowest setting possible. Same problem. My computer is not a slug. AMD Athlon 64 processor 3500+ 2.21ghz with 2gb of Ram and Creative SB Audigy 2.
Again I say this only seems to happen on deck 2.
have you even atempted to replicate this before you go throwing out solutions?
geposted Wed 27 Sep 06 @ 12:15 am
Did you uncheck safe mode in the performace tab? It is really not needed in your case.
geposted Wed 27 Sep 06 @ 3:15 pm
Hi All
I know this is totally off the topic but, please could you let me know what software I can use to rip my music dvd's. When I rip now with decrypter, it won't allow me to save them as single tracks, any ideas would be great. ps sorry off the topic, but thanks
Rgds
Wallet
Rgds
Wallet
geposted Wed 27 Sep 06 @ 4:03 pm
Wallet. You should open a seperate thread for this.. But to answer your question you can simply use windows media player. Update to newest version. Make sure you have the mp3 plugin. I also use simply CD. Works good. There are a number of programs out there though. Roxio, ect... Some cost, some don't.
geposted Wed 27 Sep 06 @ 4:55 pm
I tried unchecking that box. No change. I did try running up the quality and the problem seems to go away?? I am still trying turning on and off items to see what exactly it is. Also just to eliminate the sound drivers as a problem, I upgraded to the newest version. Still on the lower settings it continues to do it only on deck 2 with the vocals.
Am I the only one that is seeing this problem?
geposted Thu 28 Sep 06 @ 5:28 am
after some more tinkering with the settings it seems to be the master tempo setting. When I set it to manual instead of auto, it seems to resolve the issue, but the question is why.
any ideas?
any ideas?
geposted Thu 28 Sep 06 @ 5:43 am
