Can anyone explain why when I am using a TIME CODE CD with a CDJ800 and I move the slider on the CDJ800 all the way to the top or bottom the screen display is about 75% from either the top or bottom of the picch. I can actually move it with the mouse all the way and while moving it it changes the pitch or speed of the song.
Also, how come when I move the pitch on the CDJ, the screen display and what I hear lag behind. on 3.4 it was instant.
Thanks..
Thanks..
geposted Fri 25 Aug 06 @ 8:37 pm
The default pitch range for VDJ is -34% to +34%. The pitch of your turntable is probably at -10% to +10%...and some can be adjusted to do different pitch ranges, for example the cdj100 can be set to +/-6% and +/-16%. You can also go into the VDJ config and change its range between +/-8%, +/-12%, and +/-34%.
--Andrew
--Andrew
geposted Sat 26 Aug 06 @ 7:49 pm
