how do i congifure VDJ 4.0 to work w/ my TCVs???
geposted Fri 25 Aug 06 @ 10:06 pm
nevermind i figured it out..
geposted Fri 25 Aug 06 @ 10:46 pm
How did you do it?
geposted Thu 31 Aug 06 @ 4:25 pm
can you make a guide ?
Seems many cant figure this out, and it would be really helpfull ;)
geposted Thu 31 Aug 06 @ 5:17 pm
yeah sure no problem... here it is step by step (SETUP FOR TCVs on VDJ 4.0)
1. Open VDJ, Go click on CONFIG (upper right hand corner)
2. Click the SOUND SETUP tab.
3. Click the down arrow on INPUTS.
4. Select TIMECODES the one w/ two turntables and the laptop.
5. Next click on the down arrow for OUTPUTS.
6. Select EXTERNAL MIXER.
7. Next click the down arrow for SOUNDCARD(S).
8. Select Maya44 USB. or AISO if using a different soundcard than the Maya44.
9. Try to use your timecoded vinyls now and see if that works for you.
-Other than that, if you're still experiencing problems, I would follow VDJ's website instructions on setting up your TCVs and Turntables to your computer.
geposted Sat 02 Sep 06 @ 9:44 pm
Hey DJ in Norway, CSTOLL has a great guide for setting up time codes but its on the software forum, anyway you can copy that guide to this forum?
Here is the link
https://virtualdj.com/forums/13647/Software_Technical_Support/TCV_Setup_Manual_and_Additional_Instructions.html
Paisan
Here is the link
Paisan
geposted Sat 02 Sep 06 @ 10:25 pm
