Hey Guys, Does anyone know how to fix the distortion i am getting when i scratch using my Turntables??? When i use my cd players on the maya soundcard....i recieve a 100% timecode quality reading without the software preamp taking affect, and the scrathing is amazaing......Problem is when i hook my Turntable up to the maya to use my TCVs, auto config selects "software preamp" in order to recieve 100% Timecode quality, bad side of that is that when i scratch at those settings, the sound is very distorted and sounds like a moving train :( anyone that has a way of me fixing this pleasee pleaase share that info with me.....I have tried eveything from buying new cartridges, adjusting buffer, adjust latency.....nothing works...so help me please someone, thanks you
geposted Fri 25 Aug 06 @ 10:26 pm
turn off software preamp for tt's too...
Or is the signal too low ?
With sofware preamp, it sounds like your are getting too loud signal
And also, remember to ground your tt''s to your PC
geposted Sat 26 Aug 06 @ 4:21 am
