Can someone be so kind and explain how to import the VDJ 3.4 database to the database of VDJ 4.0?
geposted Sat 26 Aug 06 @ 3:35 am
Well, I haven't tried it myself yet, so i'm not sure, but i reckon you would just copy and paste?
Cheers...and keep spinnin...:o)
P
P
geposted Sat 26 Aug 06 @ 3:38 am
yupp.. thats just it;)
The VDJ3.4 database >> vdjdatabase.xml
The VDJ4 databse >> vdjdatabase(your windows account name).xml
Just copy the 3.4 database over the 4.0 (making sure it has the full name as descibed above)
geposted Sat 26 Aug 06 @ 3:56 am
aaah i see thanks ^_^
uuuhhmm... another thing.... oone of my TCVs seems to be running time strech, the other one does not...thats weird :-) any idea? xD
geposted Sat 26 Aug 06 @ 4:11 am
yes.. look in the skin, for the KEYLOCK button, and turn if off..
On some PC's it seems that VDJ starts with keylock on for one deck as default (including my PC)
Just turn it off;) in skin
geposted Sat 26 Aug 06 @ 4:13 am
o.o got that, thank you, now 4.0 rulez ^_^
geposted Sat 26 Aug 06 @ 4:32 am
ok i did the same thing and I lost my playlists from itunes and vj3. how do I get them back?
geposted Sat 26 Aug 06 @ 6:55 am
Thanks for posting this up, I was wandering the same thing and voala it's back to regular database!
VDJ 4.0---> Greatest thing since VDJ started. Yes that means that even the older versions are better than sliced bread.
I was at a bar tonight not working, but the dj there i showed him 4.0 and i think i converted a pcdj guy to VDJ. just showing him what i could do and how well. compared to his pcdj.
geposted Sat 26 Aug 06 @ 9:48 am
Just add the playlist folder as favorite (its located inside your Virtual DJ install, called "playlists")
That way you have it all back, in VDJ4;)
geposted Sat 26 Aug 06 @ 2:12 pm
IMPORTANT: all favorite folders and the new "virual folders" are stored now in the xml database file. In 3.4 was stored in registry.
BIG advantage: mobility and unlimited folders now...
In 3.4 favorites was limited to 10..
Let's start focus on the hidden goodies this update has...
geposted Sat 26 Aug 06 @ 4:01 pm
I hope there's a hidden goody that allows a photo slideshow to AUTOMATICALLY run when no video is present as 3.4 did. It's looking like I have to manually turn this on/off constantly. Please tell me I'm wrong.
geposted Sat 26 Aug 06 @ 5:11 pm
