are the playlists standard playlists like winamp uses? In other words, can I create a playlist on winamp on my home computer and then install it in virtualdj and have it run (I keep the video libraries identical in folder structure, drive letter and name, etc. between the two computers). If so do I just drop it in the playlist folder in virtualdj's main program folder?
geposted Sat 26 Aug 06 @ 4:17 pm
Should work if the structure and filenames are indentical, Won't hurt to try, just drop it in the C:/Programfiles/VirtualDj/Playlist folder
geposted Sat 26 Aug 06 @ 6:14 pm
That works, thanks
geposted Sun 27 Aug 06 @ 5:05 pm
