Forum: VirtualDJ Skins
Topic: Converter Skin ATOMIXMP3 => VIRTUAL DJ
geposted Fri 04 Jul 03 @ 8:07 pm
new of the converter of the skin version beta 0.90 correction the text cue and the song_pos.
tested of skin :
- Darkun 2.2
- DarkfunbluePlus
- atomix silver screen
- ChaNinja_1024x768
- Default (atomixmp3)
- Denon1800F
- Gemini
- greece pro 2,1
- JN-CLASSIC_1024x768_v2.1 (2nd edition)
- JN-SILVER_v2.2 PRO
- Multiview
- NumarkTTX1v2.2
- Pioneer CDJ 700S
- Stanton
The all fonctions is fonctionned and converted for VDJ.
currently I seek the possibility of creating one milk on the curve of rate/rhythm via the XML. If you have comment....
i try convert jn-classic to vdj format .... give me error message when try to open skin?
yeah i got an error when i tried to convert a skin too. looks like we'll just have to get in there and change all the tags ourselves.. oh well.
phatty720
dave
phatty720 : what is the skin name you try to convert? and the line number?
DJ Maboul & I must still modify some bugs.
Gwenn.
no matter what I do, when I load the skin after using maboul's converter I get a pop that says there's an error on line 0. I'm wondering if there's special characters, or formatting characters that have been put in that aren't detectable in notepad or wordpad. I'm probably just going to change all the xml myself. The skin i'm trying to convert is from my bassik combo zip file, bassik blu.
phatty720
dave
I will remake test this evening to see what do not go.
Note you must put file XML to be downloaded in the repertory of skin of virtualdj and to put file to him BMP of the skin. File XML and BMP must have the same name.
i found this and if i remember correctly one of the closing tags is missing a "/" e.g
Beta 1.01
Veiled correction of the bug of posting with the memo pad.
Who caused an error line 0 in VDJ
Correction of the synataxe Chan="bolt" in Chan="both"
Correction of the Visual code.
Addition of an automatic line in the medium of the window of rhythm
maboul, I found why my skin wasn't being converted properly. Everything worked except for the browser and rhythm sections. I'm workin' on those right now and then I'll submit to vdj for the skins section. Right now it's just gonna be a straight port, then I'm gonna work on getting the new features on the skin.
good work with the converter!
phatty720
dave
p.s. I just finished those sections, and am workin' on a few small issues. It'll be submitted tonight.
Hey DjMaboul
Do you still have this converter, im looking to convert some atomix skins to use with vdj3.
thanks man
dj maboul, doesn't look at the forums anymore.
the converter was very difficult to use, and it was only compatible with the 1.xx versions of VDJ.
Doh. Thanks for the reply dj maboul. Looks like i might have to just remake this skin for vdj.
Thnx again
