Where do I got to change the pitch contol, I look under options and I cant seem to find where to set the pitch so the songs dont sound funny when it is changed either up ir down
Thanks
Thanks
geposted Sat 26 Aug 06 @ 11:44 pm
Press the KEY-LOCK under the pitch control. You can also make a shortcut for KEY-OFFSET. Play around with it and youll get different sound.
geposted Sun 27 Aug 06 @ 12:55 am
Got it thanks...ove the 4.0 :)
geposted Mon 28 Aug 06 @ 1:53 pm
The function master_tempo() is still available if you don't like the way that the function key_lock() works
geposted Mon 28 Aug 06 @ 3:44 pm
That was just what I was going to ask.
Personally... I prefer to hear a song goes faster or slower, than using a master tempo.
geposted Tue 29 Aug 06 @ 11:23 am
