Ok when I am scratching there is this white box around my cursor and it lags sometimes and skips. Is there anything I can do to make it run more smoothly?
geposted Sun 27 Aug 06 @ 10:12 pm
what are your Pc specs?
geposted Sun 27 Aug 06 @ 10:28 pm
How do I find my specs?
geposted Sun 27 Aug 06 @ 10:41 pm
right click the my computer icon and select properties
geposted Sun 27 Aug 06 @ 11:56 pm
Intel Pentium III processor
551 MHz,128 MB of Ram
geposted Mon 28 Aug 06 @ 12:17 am
Your system is way underpowered to run VDj correctly, the minimum you need is 850mhz 128mb ram
However 128mb of ram is also rather low, i would suggest at least 512mb, this is the minimum for audio only
geposted Mon 28 Aug 06 @ 1:22 am
The recommended configuration is:
- PIV 3 GhZ computer
- 1024x768 SVGA video (nvidia card strongly recomended)
- 4.1 DirectX compatible soundcard (with front and rear separate outputs)
- 1024 MB RAM
- 200 MB free on the hard-drive
geposted Mon 28 Aug 06 @ 10:33 am
