Topic: 4.0 pitch
Maybe i missed something within the forums but why is it that the +/- pitch buttons in the 4.0 skin act more like pitch bend buttons instead of how they were in 3.4.
geposted Mon 28 Aug 06 @ 3:00 am
Because they are indeed pitch bend buttons -)
Well explained ;)
Is there anyway i can change this in the xml?
I'm having a problem with pitch bend also. I've reverted to v3.4 till I can figure out how to "nudge" without change the pitch. Is there an option for this?
Editing the XML File: (Full.XML, other files may use different line numbers, but the line should be the same, and have to be changed in the same way)
Line 444:
<button action="pitch_bend" chan="1" value="-256 temporary">
Change to:
<button action="pitch" chan="1" value="-256">
Line 452:
<button action="pitch_bend" chan="1" value="+256 temporary">
Change to:
<button action="pitch" chan="1" value="+256">
Line 887:
<button action="pitch_bend" chan="2" value="-256 temporary">
Change to:
<button action="pitch" chan="2" value="-256">
Line 895:
<button action="pitch_bend" chan="2" value="+256 temporary">
Change to:
<button action="pitch" chan="2" value="+256">
And the buttons should work as nudge buttons like they used to in 3.4.
Also, as a side point, you can also change the value "256" to "128", or even "64" to make the nudge adjustments finer and more controlled, or use values like "512" to make the pitch nudge bigger, and therefore less controllable.
Steve
Thanks a lot man. I'm gonna try it out.
It's there a posibility when I move the wheel at my mk2 not to change the song's pitch (like master tempo). Excuse me, but i don't know how to explain myself. I hope that you understand me :D
What you want to do, scratch?
If so, yes... Check "use jogwheels to scratch" in VDJ controller setting
No... when i nudge the sound to be the same(not to change de vocal pitch). for example when master tempo is enabled or disabled and you change the pitch. when is disabled the song's vocal is changing too, when is enabled is changing only the bpm and the rythm...
I am trying to make a combo button, left click will pitch bend while right click with change the pitch, for example [not that this works]:
<button action="pitch_bend" chan="1" value="-256 temporary" rightclick="pitch" chan="1" value="-32">
I dont know the correct coding to make it work, if its even possible. Can someone please correct it?
@steve_djdawson. You're a god among theives. Thanks alot everything worked perfect.
Your welcome Manta, I wish I could get the motivation to finish one of my own skins :D
