Just got the new version 4.0 not sure were the beatlock button has gone. Is it called something else or has it just been removed it was in version 3.4.Thanks
geposted Mon 28 Aug 06 @ 4:00 pm
The "Beatlock" button is now known as "Sync" on the 4.0 skin, however, the sync button (to my knowledge) cannot be locked on like the one from the 3.4 skin. At least not without editing the XML file of the skin.
Steve
Steve
geposted Mon 28 Aug 06 @ 6:37 pm
Left click sync
Right CLick Synk & Lock
geposted Mon 28 Aug 06 @ 6:38 pm
I don't see any difference pressing right or left.
Nothing lights up like pre version 4 did to say it's locked when I press the right mouse button on Sync so if I press it again will it unlock it?
I'm never going to know if I have locked a song in or not :(
geposted Mon 28 Aug 06 @ 8:13 pm
Beatlock is now mapped to keyboard shortcut "B" by default. Once pressed, it will lock in sync.
geposted Mon 28 Aug 06 @ 8:37 pm
OK, but how do you know if it's locked or not?
geposted Mon 28 Aug 06 @ 8:41 pm
I tried right click & left click and yes it does sync the songs but it dosnt lock the beats in as previous version. Has beatlock gone permantley or is there some way to get it back ohh and i tried shortcut using b and that only operates the same as hitting the sync button
Thanks Dave
Thanks Dave
geposted Tue 29 Aug 06 @ 10:40 am
As I read in previous postings on this subject, the only way to have it engaged is by pressing SHIFT+B on the keyboard; then the SYNC button will light up, as we know it from 3.x versions.
I am wondering if there is any mouse shortcut for this?
If anybody found it, can please let me know?
geposted Thu 14 Sep 06 @ 10:26 pm
geposted Fri 15 Sep 06 @ 1:22 am
If it is locked if the Sync button for the deck looks like it is lighted. It is fully colored.
Try pressing SHIFT+B and you'll see.
geposted Fri 15 Sep 06 @ 3:43 pm
I think in the latest skins right click doesnt lock, but it does sync and play
Theres plenty of Version 4 skins with beatlock in the downloads section I know my D1 skin has every feature version 4 can offer on the skin
so it will be a excellent skin to test everything on https://virtualdj.com/addons/skin.html?id=2149
or for a 3.4 / 4.0 with beatlock try this one https://virtualdj.com/addons/skin.html?id=2301
theres many modded 4.0 default skins that also have beatlock, or the right click sync to lock
geposted Fri 15 Sep 06 @ 6:54 pm
It's just "B" by default, not "SHIFT-B". Like others said, SYNC button on default skin stays lit when activated.
geposted Fri 15 Sep 06 @ 7:17 pm
Hello everyone! i think that this "BEATMATCH" Thing is there but mostly in this new version, everything in it is a little more dificcult to work with. you need to press the letter "B" to lock the song but... in the early version you could do it more easylly with the mouse. besides. for all the shortcuts to be memorised you need to have a mega brain, ( i know i dont have it) i guess that we've got used to have averything handy in the 3.4 version and that's whats killing some of us that are not used to going to all the short cutting and stuff like that. personally... i think i like the earlier version of vdj better.
geposted Sat 16 Sep 06 @ 2:37 am
