I just downloaded the 20 day trial to see how this software performs and it is scareing me a bit.
Compaq Presario R3000
X86 AMD processor
512mb RAM
XP service pack 2 build 2600
Not real sure why this is happeneing. Last time I tried vdj it was flawless.
Any ideas?
X86 AMD processor
512mb RAM
Any ideas?
geposted Mon 28 Aug 06 @ 8:50 pm
No really guys...not sure what is going on here but nothing will play. It just grabs the first little bit and loops or something. Very very strange!
If I grab the records and "scratch" it will play if I forward spin or backspin but then when I let go it just repeats the last sounds it made.
Any hints would be great as I do not want to buy this and get something that will not play correctly.
Also what is the difference between regular and pro versions?
geposted Tue 29 Aug 06 @ 8:27 pm
Read this thread if you're using 4.0 trial:
https://virtualdj.com/forums/54262/General_Discussion/PLEASE_READ_-_PERFORMANCE_SETTING_OF_VDJ_4.html
The internet special offer is cheaper and downloadable version of VDj PRO. Basically the same software, just different package ;)
Quote :
geposted Tue 29 Aug 06 @ 10:38 pm
It looks like it is 3.4.
I looked through the config settings but do not see anywhere where I can turn down the performance of the software.
Is there another thread I am missing for setup help on 3.4? It looks like 3.4 was pretty solid but for some reason I cannot get it to work on my machine.
Currently I use PCDJFX with KJ plugin and also run Sunlite DMX software at the same time. I did not think performance was going to be an issue but it looks like it is. I just wanted to get a new software that had video capabilities but I am not using the laptop for that reason.
geposted Wed 30 Aug 06 @ 10:26 pm
demo is 3.4 yes...
A good thread about solutions for skipping can be found here:
https://virtualdj.com/forums/1180/Software_Technical_Support/_Skipping_____Possible_causes_and_solutions___WIN_XP.html?
Hope that helps :)
Hope that helps :)
geposted Wed 30 Aug 06 @ 10:51 pm
