Is there a way to keep VDJ4's cue button (and also on a DAC-2) from creating cue points? I prefer to just hit a separate cue button (not the one next to the play/pausebutton) or using the crt-1, crtl-2, etc. I like using the cue button (the one next to play/pause) to jump from cue point to cue point.
geposted Tue 29 Aug 06 @ 7:33 am
the DAC-2 is a tricky one, but download the new VJ2 DAC-2 mapper in the Download, Plugins, External Tools - Make sure it's the one for VDJ4, in order to set cue 1 you have to hold the shift button on the DAC.
As for the SKINs well it could be modified to do what you are asking? Which skin are you using?
cstoll
cstoll
geposted Tue 29 Aug 06 @ 7:43 am
I am using the one that came with the download.
geposted Tue 29 Aug 06 @ 7:48 am
Try this one - read the enclosed readme for all the functionality.
https://virtualdj.com/addons/download.html?addon_id=2178
cstoll
cstoll
geposted Tue 29 Aug 06 @ 11:14 pm
I feel the same way. Cue points take time and care to get set just right. Hitting the cue button accidently when the song is paused (instead of playing) doesn't offer enough protection for my precious CUEs.
I have a DAC-3 that I am still learning how to use. Is it true that the DAC-3 BOGGIS map can be configured (user parameter #1) to keep the CUE button from setting cues?
Thanks!
geposted Tue 29 Aug 06 @ 11:28 pm
lajolladjs wrote :
I don't know if I did the quote thingy correctly.
I agree, lajolladjs. It takes a very long time to create the cue points where you want them. It helps so much for when I loop. Cstoll, I already downloaded that mapper, as you suggested earlier. Thanks. I haven't had a chance to try it out yet.
geposted Wed 30 Aug 06 @ 1:07 am
lajolladjs wrote :
[quote=DeeJay EL]
Yes, you can configure my DAC-3 mapper so that [CUE] just performs stop without setting cue points (Which can still be done using [CP]+number.)
geposted Wed 30 Aug 06 @ 4:25 pm
