Had my first live 'crash' with 4.0 unfortuanatly Sunday night. Put on a CD and all was fine after that.
I got the window that popped up saying recover - which restarted VDJ pretty quickly - all was fine after that
I used it fine the day before live no problems.
Wasn't particually doing anything 'cpu intentisive' but I was playing an mpeg video. (wasn't doing any keylock or anything like that).
I must say though - I never have had a crash with 3.4.
Only difference in my settings is i've set the latency to 128, maybe i need to change this to 256.
I have save mode unticked and overclock ticked. (as suggested on these forums for laptops).
Its a fairly powerful laptop - 1gig mem, 2ghz amd turion 64bit processor. 128 x 700 ati video chip.
Using maya44usb soundcard.
Any suggestions on adjusting my settings for greater stability under 4.0 would be appreciated.
geposted Tue 29 Aug 06 @ 11:37 am
for maya better set latency to "auto" this will allow you adjust the latency from maya's control panel like usual. (recommended)
As for the crach, was the mpeg video a big file in length ? minutes ?
what is your max load settings ?
Is hardware acceleration working for video in your laptop ?
geposted Tue 29 Aug 06 @ 2:17 pm
Its not a good idea to change the latency settings in a live situation.
geposted Tue 29 Aug 06 @ 2:57 pm
I didn't change it in live situation - i changed it to 128 before the gig.
I done another gig last night on 256 latency and it all worked fine. I will leave it set on Auto as you've suggested.
I think the crash was maybe because of that, anyway's it's all fine now. Thanks
geposted Wed 30 Aug 06 @ 10:19 am
