- Half, Quarter and 1/8 skip beat
- Seeing more than 10 cues on the songpos
I'm willing to dish out 300$ just for those little additions ...
geposted Tue 29 Aug 06 @ 6:25 pm
well you have more money than sense then
geposted Wed 30 Aug 06 @ 12:40 am
Nope.
Cues are VDJ's strongest point.
Being able to completely map out a song with cues would be priceless.
(and it's really a question of changing "MAX_CUES=10" to "MAX_CUES=20"
2 seconds of work.
And I'm willing to pay 150$ for it.
(and another 150 for the skip beat stuff)
2 seconds of work.
geposted Fri 01 Sep 06 @ 6:27 pm
Hi Raz,
can you tell me your usage example for these functions:
Another user has also requested them, and I've been wondering how would they be useful to me, but I really can't find an example.
Regards.
Regards.
geposted Fri 01 Sep 06 @ 6:33 pm
DJ Raz wrote :
Nope.
You're right only first 10 cues shown on the songpos, but others shown in the moving waveform.
And i had the curiosity how many cues i could set...............
tada....
999,999 !
Are we crazy ? Virtual dj supports 1 million of cue points...!
Back to your problem - another suggestion (for ..free): create a skin with lets say 20 cue timmers.
Then you'll have an overview of 20 cue points, even if not all of them shown in songpos
geposted Fri 01 Sep 06 @ 8:06 pm
@Erxon
The skip beat is just for playing with the song.
Skip Beat -1 can make for cool effects when done at the right part of a song.
For example, try skipping -1 (timed properly) 3 times just before the chorus of a song.
With -1/2, -1/4, and -1/8 we could do even more ... :)
geposted Mon 04 Sep 06 @ 5:58 pm
@apopsis
Wow 1000000 cue points... that's... well that's insane :)
Yeah they do show on the waveform, but its not very useful...
Also we can't delete or rename cue points > 10 manually, We have to make shortcut for that.
Making a skin with 20 cue timers is a good quick fix, but it would make for wayyyyyyyy to many numbers on the screen!
geposted Mon 04 Sep 06 @ 6:03 pm
You can make them as small as you want using the font size, even as a dot...
In fact i usually dont want to see the actual number (time) but i use them as visual indicator to see what cues are set.
For example i can have cues 1, 3, but the cue 2 empty for some reason.
You can also set right click on the timmer to delete the actual point.
geposted Mon 04 Sep 06 @ 6:31 pm
DJ Raz wrote :
@Erxon
@Raz
Thank you, I see your point, but I rather use BeatGrid plug-in for such occasions, would be especially lovely if that plug-in was improved to support 2nd half beat (2/8) sampling & repetition, not just the first part (1/8). :)
Regards.
geposted Wed 06 Sep 06 @ 12:00 pm
