I have noticed that reactivity settings in VDJ4 are gone... I had trouble when I was back using 3.1 and I had it set to low and it fixed the problems, and didn't look back through 3.2, 3.3, 3.4. I do notice that there are the performance settings, but I notice this doesn't affect the reactivity when I'm playing music. Is it labelled something else, and can anyone provide any tips in VDJ4 to get maximum performance as I'm a touch worried I don't have the power to run it without any skips through a gig. Please don't suggest going to the sticky's at the top of the Software Tech Support forum as I poured through it intensively in 3.1, and I'm looking for VDJ4 tips.
geposted Wed 30 Aug 06 @ 8:39 am
Give me your computer specs, soundcard/drivers /usage and i'll try to suggest you the best settings.
geposted Wed 30 Aug 06 @ 5:28 pm
I just want to change the reactivity settings. I know what other settings I should be at for my latency. Can I change the reactivity or not?
geposted Thu 31 Aug 06 @ 2:35 am
