Hola!
I have upgraded to version 4.0, so I thought I would download some new effects for it, the effects I have downloaded wont appear in the effects on the skin even though it said "installation complete".
Can someone tell me where I'm going wrong so I can use these new effects....?
Regards,
Carlos.
Regards,
Carlos.
geposted Wed 30 Aug 06 @ 8:56 pm
some effects are not v4 ready. you wull have to wait some more time.
geposted Wed 30 Aug 06 @ 9:09 pm
Cool,
No worries, I was thinking my pc was on it's last legs as I have had other problems since upgrading.
I will chill with the effects I have til the problem is sorted!
Cheers!
Carlos.
Might be an idea for the future to put information on downloads as to which version they will run on.
Cheers!
Carlos.
geposted Wed 30 Aug 06 @ 9:15 pm
