I'm trying to add the same Loop sampler Rec function that is on the default skin in vdj 4.0 to my mapper. I think i should use "sample_rec_loop", or ?
I guess that when i press button down i should start rec and on release stop rec. How do i use it, what are the parameters to do this.
geposted Thu 31 Aug 06 @ 10:56 am
No, because there is no "Momentarily" parameter on this shortcut. It will record 4 beat loop with default parameter or if you made a longer loop manually it will record that.
geposted Thu 31 Aug 06 @ 12:11 pm
