I am having a problem changing my skins. I have followed the instructions given and when I open the folder c:\program files\automixmp3\skins i see them all there. However when I try to change the skins in the program it only shows the default.
geposted Fri 01 Sep 06 @ 7:20 pm
there probably not going into the right folder check virtualdj folder in the program files and see if there in the skins folder
geposted Fri 01 Sep 06 @ 7:50 pm
Thanks, I am using atomix. Would there be a virtualdj folder? I cannot locate one
geposted Fri 01 Sep 06 @ 9:50 pm
If they are in zip files, try to unpack them in Skins folder of your AtomixMp3.
geposted Sat 02 Sep 06 @ 6:40 am
