Forum: Old versions
Topic: Suggested PC Requirement to run VDJ 4.0
Ok Guys cannot find the answer to this question once and for all, can we have the recommended and Maximum PC Requirement to run this software....I think alot of people will like to know
Thank you
geposted Fri 01 Sep 06 @ 8:33 pm
pulled this off of the Products>VirtualDJ>Features tab
https://virtualdj.com/products/virtualdj/description.html
The minimum requirement to run Virtual DJ is:
PIII 850 MhZ computer
1024x768 SVGA video
DirectX compatible soundcard
128 MB RAM
20 MB free on the hard-drive
The recommended configuration is:
PIV 3 GhZ computer
1024x768 SVGA video (nvidia card strongly recomended)
4.1 DirectX compatible soundcard (with front and rear separate outputs)
1024 MB RAM
200 MB free on the hard-drive
Paisan
minumum specs are audio only, you cant run Video's (properly) off that low of a config.
