Hey .. I just purchased the program and was told to get "Maya USB 44" and there is none available anywhere.... What else can I use...Any info would be helpful..
Thanks
Thanks
geposted Fri 01 Sep 06 @ 10:52 pm
you can use the U46DJ or the M-Audio Audiophile USB. I personally cant give you a choice because I havent tried either yet. I will probably be getting the U46DJ but I dont know yet.
I wrote a post here https://virtualdj.com/forums/55209/Hardware_Technical_Support/choosing_a_audio_interface.html
to see what other people decide for me to do.
U46DJ
http://www.floridamusicco.com/proddetail~prod~u46dj.htm
http://www.floridamusicco.com/proddetail~prod~USBAUDIOPHILE.htm
U46DJ
geposted Sat 02 Sep 06 @ 12:13 am
Thanks
Thanks
Maybe you should enter your serial# in your profie so we all know you are legit..
Right now you might as well be using a cracked copy and fishing for answers..
geposted Sat 02 Sep 06 @ 12:23 am
Now thats a constructive discussion...
geposted Sat 02 Sep 06 @ 4:16 pm
Moderators, I would like to see this insulting posts deleted, not just locked.
geposted Sat 02 Sep 06 @ 6:02 pm
I would put my serial number in but if the program is mud , I am going to send it right back.. So far I am not happy with it.. So settle down would you..
Thanks for the people who are trying to help
geposted Sun 03 Sep 06 @ 7:00 am
Well, if you gonna send it back I presume you don't need help for it, right?
geposted Sun 03 Sep 06 @ 7:41 am
@mixitup -- please ignore those posts --
Not sure of 'razor950' true status - but his suggestions are valid and should be pursued. Several have done well with the U46DJ as a viable replacement to the Maya 44 USB.
Also, go ahead and register your serial with your profile. If you choose to return the software (which I hope you won't) then the TEAM and SUPPORT staff will make things right upon return.
cstoll
cstoll
geposted Sun 03 Sep 06 @ 8:51 am
