I'm trying to figure out why when I play songs with version 4.0 they aren't on tempo when I play the same song in other programs (i.e. Winamp, Windows Media Player, etc.). When the pitch is at 0 it doesnt sound right. I have to put the pitch at about 2.5 to get it to match the other programs. Anybody know why? Anybody else having the same issue?
geposted Tue 05 Sep 06 @ 1:29 am
using timecode?
geposted Tue 05 Sep 06 @ 1:34 am
nope, using just the software itself.
geposted Tue 05 Sep 06 @ 1:43 am
hmm.. Im using the time code and it appears that with timecode its taking time to respond to the key-lock to keep the vocals from sounding like a chipmunk (like master tempo on the CDJ800's) ..hmmm
geposted Tue 05 Sep 06 @ 6:36 am
Just tested mine. Plays at exactly same speed as Winamp. Sometimes Frequency settings might effect the pitch. Check your soundcard settings for 44khz or 48khz.
geposted Tue 05 Sep 06 @ 10:01 am
Set the latency in the performace tab to AUTO
geposted Tue 05 Sep 06 @ 3:22 pm
^^Thanks abnorm. It was a sampling rate issue. The Maya44 was set to 44, and was causing the problem. Thanks for your help.
geposted Wed 06 Sep 06 @ 12:39 am
