Has anyone try the cdj 800 with vdj and tccds?
any info about this setup will be apreciated!!!
thanks
thanks
geposted Tue 05 Sep 06 @ 3:29 pm
I did and it works, but i remember a little too strong signal from line out. You will have tu lower the signal using audio editing software, but i am not sure. Maybe only i had this problem. But it works.
geposted Tue 05 Sep 06 @ 3:39 pm
Hi Xeon!
the strong output signal cannot be setup correctly with the external mixer gain?
did you try all buttons? cue, skip, loops...
please tell us about your experience!!!!!!!
thanksssssss
thanksssssss
geposted Tue 05 Sep 06 @ 4:01 pm
Line out from cd-player goes directly to sound card (maya44 in my case). I used maya44 controll pannel to make everything like i do when i have TT connected to it, but there was still too strong signal. I just made it lower and then it worked. I can't try it again because i don't have cd-player at home anymore. I tryed with denon 3000, 3500, 5000, pioneer 100, 200 and 800. for now each of it works, but i know that with denon 3500 and 5000 and pioneer 800 i had to lower the signal. that's all.
i tryed loops on denon and it worked as i remember.
geposted Tue 05 Sep 06 @ 4:22 pm
