I just upgraded to V4 however when i try to use my TCV's, no sound is outputted. I know in v3.4 i had to change some things in the registry, but i'm confused on how to change it in v4. Any help would be greatly appreciated.
geposted Tue 05 Sep 06 @ 6:21 pm
Join the club bro! I am in the same boat as you, ans its getting annoying. I kindof want my ver. 3.4 back, at least it worked
geposted Tue 05 Sep 06 @ 6:57 pm
What soundcard ?
geposted Tue 05 Sep 06 @ 9:55 pm
what is the TCV doing? do they work just no sound? do you get 100% what card and drivers used?
geposted Wed 06 Sep 06 @ 3:56 pm
one thing that stumped me for about 10 minutes was that the gain in the asio config>advance setup for some reason defaulted to zero. Once I raised the gain to the proper level all was good. provide more information by answering L2 and Norway's questions and I'm sure we'll get it straightend out for you.
geposted Thu 07 Sep 06 @ 8:56 pm
The registry settings value names have changed in v4. I had the same problem. See https://virtualdj.com/forums/54612/Software_Technical_Support/Timecode_Setup_VDJ4_0___M-Audio_1010-LT.html for the new names.
geposted Fri 08 Sep 06 @ 7:25 pm
