I am looking to incorporate a PC into my rig w VDJ 4. Currently I use a laptop with a Maya 44 USB soundcard but I would like to build something into the actual flight case instead with everything put in.
I was looking at some of these ideas. What does anyone think about these? Has anyone been using any of these types. I will upgrade the memory in any unit to be either 1GB or 2GB and will probably still use an external USB hard drive for all the music.
Shuttle X-100
http://sys.us.shuttle.com/X100_4.aspx
AOpen MP945-VXR
http://minipc.aopen.com/Global/spec.htm
I was going to build a full computer into the case and put it into a rackmount case but I would need something with a little shorter depth than most of the case I have found.
Shuttle X-100
AOpen MP945-VXR
geposted Wed 06 Sep 06 @ 4:44 am
theres a 2u rackmount case that's only 14" deep, and its what i have been using inside my grundorf case
http://www.rackmountnet.com/Rackmount-Chassis/2U-Entry-Level-Chassis/2U-Rackmount-Chassis-5-bays-139-depth-power-supply-optional-IPC2ES/page/1/sort/1a/
geposted Wed 06 Sep 06 @ 5:44 am
