As I'm using the Hercules DJC, most of the keyboard maps that come by default are not useful as far as they can be accessed via the console.
I was able to map some keys to control the gain of each desk independently, and also to start and stop recordings, but I now would like to map some keys to make it change the window. I would like to map 3 keys to access these windows, "Music", "Search" and "Rec".
Does anyone knows how to do it?
Also I would like to know if there is a way to light the leds in the keyboard when an action is happening. Just in case my explanation is not clear, I would like "bloq desp" to be on when I'm recording the mix to an MP3 (So I don't have to switch to the rec window to be sure), and to be off when I stop recording.
Thanks.
Thanks.
geposted Tue 06 Jul 04 @ 8:07 am
