i am finding that when i open vdj sometimes some of my bpms are missing. all my files have been analysed. and other times i open vdj they are there.
anyone any ideas to resolve the problem????
cheers dave :)
cheers dave :)
geposted Wed 06 Sep 06 @ 2:56 pm
It's most likely to do with some of your filenames having 'dodgy' characters in,
Try opening you're virtual dj database xml file in internet explorer, if it comes up with an error it probably means the next track has a dodgy character in the filename.
If you then look at the file in notepad you can work out which track it is, you'll then need to rename it.
Chances are you've got a few of these, I had about 50, once i renamed all these files I was able to re-analyze the lot.
The problem is it loads the xml file top to bottom but stops if it hits an error.
Common examples of dodgy characters are quotes and aposhtro-phied e's !
geposted Wed 06 Sep 06 @ 3:47 pm
i am getting this error message in the xml file
Whitespace is not allowed at this location. Error processing resource 'file:///C:/Program Files/VirtualDJ/VirtualDJ Databas...
<Song FileName="Johnny Cash & Willie Nelson - Ghost Riders In The Sky.mp3" Filesize="2720638">
ft:1em;text-indent:-2em"> <BPM Bpm="233" />
any ideas???
any ideas???
geposted Wed 06 Sep 06 @ 4:02 pm
